error c5360 km c308
  • romario
    • Jun 2020
    • 192
    [Error Code] error c5360 km c308
    thanks
  • tsbservice
    Field tech
    • 7979
    Re: error c5360 km c308
    System 2 - 3rd page - Clean unit setting - should be Not Installed
    • romario
      • Jun 2020
      • 192
      thanks, problem solved
      thanks
      • tsbservice
        Field tech
        • 7979
        You're welcome
        • antone
          • Oct 2014
          • 344
          System 2 return off Clean Unit ...
          De install...System boots reboot!
          Sent from my SM-N981U using Tapatalk
            • 22999
            I think I'd take a look in service mode > System 2 > Cleaning Unit Setting > desired: UnSet
            • ltdiniz
              Supervisor de Campo
              • Mar 2021
              • 92
              Thanks for the tip as always @tsbservice I just solved this C5360 error on a C308.
              Enviado de meu Redmi Note 9 Pro usando o Tapatalk
              • symselu500
                • Nov 2023
                • 1
                sir i complete this process but not clear code c5360 plz help me
                • thief89
                  • Apr 2024
                  • 1
                  Salve, anche Io con lo stesso Problema Errore, ma ho risolto grazie alla soluzione di @serviziotsb disabilitando in System 2 il Clean Unit Setting. Però mi sorge un dubbio se disabilitando questa opzione può creare problemi più gravi alla Konica C458?
