C364 error- C5370
  • Gaze
    • Jan 2024
    • 5
    C364 error- C5370
    Hi Team
    I'm having a hard time on this error code: C5370.
    I've replace the fuser but still having that same issue, I tried replacing the fuser fan but still the problem persist.
    kindly need assistance on this.
  • kingarthur
    • 1325
    The fan is under the boards....it's laying down
    • jacobchentw
      • Aug 2021
      • 2
      TROUBLE RESET
      • KMFLT3CH
        • May 2017
        • 226
        The cooling fan is likely clogged with dust or debris, pretty common to see this on the old 4 and 8 series.
        Remove the rear plastic cover and you'll see it laying flat at the botton under the MFP board.
