Konica Minolta bizhub 3320 Convert to Lexmark MX310de?
  • Lx5
    • Oct 2021
    • 6
    Good morning people.
    Is there any possible way to convert this printer to it original factor? Tried to do it with firmware, but nothing... Is it actually possible or am i wasting time?
  • tulintron
    • Jul 2014
    • 668
    Re: Konica Minolta bizhub 3320 Convert to Lexmark MX310de?
    Why would you do that?
    • tsbservice
      Field tech
      • 8031
      Bad idea, old and rotten model.
        • 23010
        I don't think it's a possibility. KM loads its own operating system and firmware. =^..^=
        • Lx5
          • Oct 2021
          • 6
          if i try to upgrade it with lexmark firmware, it does upgrade and the version changes to the one that i used. that works also when i downgrade it.
          • Drivee
            • Nov 2020
            • 322
            I think that this is not possible. What is reason, toners?
            • Lx5
              • Oct 2021
              • 6
              Yes. they use exactly the same toner but lexmark's are cheaper. the only diffrence is the chip for the recognision.
              • Toxic
                • 698
                I think it is not worth hassle.
                You could simply use some replacement toners, you can find it under 50 euros.
                I use them for older 4020 and 4050 and it is working ok.
