I have this stain every 10 copy on all size... any suggestion
Stain on paper..
Tags: None
What machine is it please? Looks like transfer belt to me, possibly where the patches are printed for calibration. I would inspect the transfer belt first, every ten pages seems too many for a fuser or anything else.
I would check the paper
/try a different batch/type as well, I’ve chased a problem like this and it was the paper!👍 1 -
Hello, I would start with the cleaning blade.
Check which meter state the cleaning blade has. Two cleaning blades are installed in the device, which is swiveled at approx. 500k pages. If it is not yet overwhelmed, you can manually execute in "service mode"
Otherwise install a new part and possibly renew the drum.
-Sorry for the bad translation-Comment
I would look at the transfer belt and transfer belt cleaning unit.If you'd like a serious answer to your request:
