I'm getting Error N63 on the scanner job list (7145)
  • projectsome
    • Aug 2025
    I've tried scanning a few documents but they didn't come through. Having checked the job list I noticed some of them said Error N63.
    As it's only the larger jobs I'm guessing it's something to do with the size limit?
    I previously had someone come in and chsnge the default of the dpi to 800. How do I change the default of the dpi?
  • crm.84
    • Mar 2009
    • 15
    N-63 1. Check that binary division function is activated under E-mail(smtp) 2. Reduce binary division data size.
    Change dpi- Enter key-op mode - touch #3 scanner - touch #1 initial setting - use up/down arrow to select "scan quality" - use edit button to select desired dpi.
    All of this info is in the Networl Setup and Scanner Operations User's manual.
