Bizhub 950 different toner bottle?
  • Toxic
    • 698
    Last year i try 1 bottle replacement toner TN-911 and had problem.
    Today i get again replacement toner CET TN-911 and there is the same problem (KM does not support anymore TN911)
    Bottle dimension is the same but the grooves on top side is reversed and it overjump when machine try to rotate bottle.
    Obviously this bottle is meant for opposite direction of rotation than OEM bottle.
    Also part number is different from original toner i had in the past from KM.
    Is this TN911 meant for other region except EU or something else?
    I am thinking how to resolve this on the fastest way, i could just pour toner from this bottle to original one but i will try to modify grooves to avoid pouring.
    OEM toner is on the right in the photos.
    Does anybody use this toners and see this problem?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 950 different toner bottle?
    TN014 on the Left? Both TN911 and TN015 turns the other way.
    Decant and cry. Late night in China.
    How does that CET stuff work?
    Whatever
    • Toxic
      • 698
      Both bottles are TN911, right one is OEM left is CET.
      Can somebody confirm what is difference between A0YP031 and A0YP051 , both are TN911 OEM parts number
      In the past i always get A0YP051 and it fits ok in to the machine.
      Regarding CET, i dont know how will it go, i just got few bottles to test because this bad situation from KM.
      I am considering to try to reverse toner bottle motor direction if possible because OEM toners not avaliable anymore.
      • tsbservice
        Field tech
        • 8020
        I can imagine toners for EU - A0YP051 and NA(USA) - A0YP031 market are different and if chinesse(CET) copied NA toners you will have such problems.
        • Toxic
          • 698
          Agreed, i just cant understand why somebody from EU import incompatible toners for EU region...
          It would be interesting to see what is difference in toner supply section so bottle have oposite rotation.
          Maybe just motor have opposite direction or there is some extra gear.
          • tsbservice
            Field tech
            • 8020
            A0Y5M10400 may be the toner motor part number for US version, can you compare with EU manual?
            • Toxic
              • 698
              That one is the same, it is toner supply motor.
              Check PN for toner bottle motor , i think that one rotate bottle.
              In EU version it is A0PNM10200 DC Brushless motor /20
              • tsbservice
                Field tech
                • 8020
                He is hiding but now I see it.
                Maybe I found the difference in wiring see key 13 as B is USA/Canada and C is European type:
                13 A0Y5N13A01 Toner Control harness /A Destination A,C,D1,D3,F2,H,I,J,
                K
                13 A0Y5N13E01 Toner Control harness /A Destination B,G1
                • Toxic
                  • 698
                  Good vision, i missed it.
                  Did you check motor PN, if it is the same thing for EU and NA then must be only harness different.
                  • tsbservice
                    Field tech
                    • 8020
                    Yes motor is the same, take care and keep up great work!
                    • Toxic
                      • 698
                      Thank you my friend for hint and help.
                      Tomorrow i will remove toner supply unit and have a look, maybe i will figure it out how to modify
                      • allan
                        RTFM!!
                        • 5462
                        If its a BLDC motor then you can pull the direction pin up or down to ground to change direction.
                        Not sure if running it in reverse would work.
                        Whatever
                        • emujo2
                          • Mar 2017
                          • 1579
                          OMG...just dump the toner into the old bottle..What are you going to do??? Swap the motor out every time you get a different bottle..E
                          • tsbservice
                            Field tech
                            • 8020
                            This is always possible however some engineers like to think outside of the box. Those are I would like to work with. Damn you can even possibly train a monkey doing toner decanting
                            • wjurls
                              • Feb 2017
                              • 498
                              This! It's so easy to remove the end caps. Tape empty bottle butt to butt with full bottle and invert. Be prepared for a mess as it may not fit all the toner due to air fluff.
