imaging units C3350 to C3351
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 301
    Good morning to all. Does anyone know if you can somehow use the imaging units of the old C3350 in the less old C3351?
    By doing some modification or something?
    Thanks.
    Field technician since 1994
  • adecanmin
    • Oct 2010
    • 290
    It uses a different image unit chip. You could swap out the chip from the 3851 but the unit would need to be calibrated or it will eventually code out. I made a set up where i soldered two wires to the old chip, long enough so they are outside of the machine. I touch the wires together then release simulating the chip blowing on the board. The machine then calibrates the unit. They have image chips for the 3850 but I can't seem to find any for the 3851.
