Web licence request.
  • Max
    • Oct 2011
    • 561
    Good day ppl.
    We had two c458 devices through the trade and they have been reset. Would some one be kind enough to get 2x Web licences please?
    Would you need the serial numbers ro generate the activation code?
    many thanks
  • otphas
    • Aug 2019
    • 121
    Please send me serial number.
    • Max
      • Oct 2011
      • 561
      Thank you, Otphas. I have attached the pictures of the serial numbers. Hope it's OK.
      Many thanks.
      MAX
      • otphas
        • Aug 2019
        • 121
        You have successfully generated a License Code.
        Please save all information for future use.
        MFP Serial Number A79K021009845
        License Code: RZ8NJ-5MTN4-GZDEV-7L8GZ-NAHSW-SHKND(To enable via PageScope Web Connection)
        RZ8NJ5MTN4GZDEV7L8GZNAHSWSHKND(To enable via MFP)
        MFP Serial Number A79K021009847
        License Code: 4H7RZ-6DYWM-KB5X3-3B27A-PYMKW-KXWPL(To enable via PageScope Web Connection)
        4H7RZ6DYWMKB5X33B27APYMKWKXWPL(To enable via MFP)โ€‹
        • otphas
          • Aug 2019
          • 121
          1. Tap [Utility] - [Administrator Settings] - [Network Settings] - [Web Browser Setting] - [Web Browser Usage Settings].
          GOOD LUCK
          • Synthohol
            Certified Konica Expert
            • 5872
            Don't they license themselves? I don't re
            call having to go online separately to license web browser.
            Only there were initial I series that you had to put a license se in manually but MKM published the license #s
            If the ip subnet gateway and dns are in the copier it will license itself through the menu.
            • Max
              • Oct 2011
              • 561
              That's what I thought. But turns out you need the licence. May have had something to do with the copiers factory reset from our 3rd party supplier.
              Thank you Otphas. Much appreciated.
              • Synthohol
                • 5872
                Damn, sorry it's not going according to hoyle. I'm really shocked ot didn't work the nor.al way
                Sorry typing on a cell.
                • Max
                  • Oct 2011
                  • 561
                  It turns out it's a licence code for the copier and not the Web licence.
                  From what I read the copier comes with the licence and all that's needed is enabling the Web browser. But when I enable it it pops up with enter the licence key. As its ready from the factory where would I get the licence number if LMS only gives copier licence?
