IO checking bizhub C7000
  • ANIP87
    • Feb 2022
    • 9
    [Misc] IO checking bizhub C7000
    I did io/ckecking 98-09 with result "NG".
    Can help me fix/repair it. Please
    Re: IO checking bizhub C7000
    Might want to locate A service manual.
    • Synthohol
      Certified Konica Expert
      • 5808
      Image processing board
      line memory (SDRAM) /K
      check
      5.7.10 Printer image processing board line memory check
      (1) Usage
      When the image of a particular color is misaligned in the sub scan direction and a notable image trouble occurs, check whether there is any
      abnormality on the line memory of the printer image processing board (PRIPB).
      (2) Procedure
      1. Enter the I/O check mode.
      2. Enter "98" with the numeric keys.
      Confirm that "98-00" is displayed on the message display area.
      3. Press the Access key.
      4. Enter one of the followings with the numeric keys.
      Check that "98-##" (## represent multi-code number) is displayed in the message display area.
      Multi-Code 06: Printer image processing board line memory (SDRAM) check /Y
      Multi-Code 07: Printer image processing board line memory (SDRAM) check /M
      Multi-Code 08: Printer image processing board line memory (SDRAM) check /C
      Multi-Code 09: Printer image processing board line memory (SDRAM) check /K
      5. Press the Start key.
      During the operation-"NOW" is displayed
      The operation succeeded - "OK" is displayed
      The operation failed - "NG" is displayed
      When "NG" is displayed, replace PRIPB.
      A1DUH06011
      Image Processing Board /P Assy
