LCC Tray, kinking while lifting issues....
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys... so, I've had several of these things kink the lift tray (the main one, on the right side) while lifting paper. I've noticed that the lift cables (thin, not durable) can bend and kink, due to winding around the metal shafts instead of the pulleys.
    It seems what happens is that when the trays bounce, it can kink the lift cables off the pulleys, and then you've got uneven lift. I've ordered a set of cables, but have yet to put them on. This is the PC-410 model tray, by the way.
    Wondering if there is some kind of mod for this issue?
    Thanks in advance!
    OC
  • rrrohan
    • Sep 2011
    • 1977
    Re: LCC Tray, kinking while lifting issues....
    yeah i bet its when users keep topping up a half empty tray. the sound of it slamming down when you open lid makes me shudder everytime i hear it
    • tech51
      • 846
      When you fit the new cables, push some blue tak into the slot to stop them falling back out. Also replace the small damper that sits on the lift drive (called a dumper in the manual). This stops the tray from slamming down.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        This^^^
        I do the same thing except put a piece of mylar (with adhesive strip already on it) on the side of the cable take-u pulley. Haven't had one fail since I've done the mod. Replacing the "dumper" is key to stopping the slamming down of the stack.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Synthohol
          Certified Konica Expert
          • 5892
          those stupid notches!
          i use pieces of corona wire rubbers to wedge in the groove to keep the wire where it belongs.
