bizhub doc feeder
  • digicor
    • Jul 2008
    • 1158
    bizhub doc feeder
    i have two bizhub's that do this:
    when you power up the machine the doc feeder goes off with a jam detect, you open the doc feeder reset it and its solved? only at power up does this happen. and of coarse there is nothing in it.... what gives?
  • minimerlin
    • 851
    You need to do the sensor auto adjust for the adf.
    Please do not PM me without asking first.
    • crm.84
      • Mar 2009
      • 15
      If you get a NG for results after performing the adf auto sensor adjust, you may need a new adf control board. I have seen this symptom before.
      • digicor
        • Jul 2008
        • 1158
        I will check that out
        • Taminol
          • 171
          when you power up the machine the doc feeder goes off with a jam detect .......
          I had this on a C252, exactly the same symptoms as you. I did the sensor check and they all came out OK.
          It turned out to be Turnover Sensor PC5, it was dusty - that was it !
          I guess at initial switch on the sensor was cold?
          Then it warms up as the voltage flows?
          Who knows.
          All I know is, I cleaned it 6 months ago and haven't heard a peep since.
