Sensor location/replacement Bizhub c541
  • rightbrained
    • Oct 2014
    • 40
    I'm looking for more accurate description of sensor location and replacement procedures for my Bizhub c541. Ideally photographs as the diagram from the service manual leaves much to be desired. Specifically, for the current situation, the Tray 2 vertical transport sensor.
    Also, help with step #6 in the attached sensor check from the manual.
    Attached photo shows jam location A before it enters unit B on side panel door.
    Jame codes 1710 and 1001
  • Synthohol
    Certified Konica Expert
    • 5842
    Re: Sensor location/replacement Bizhub c541
    a parts manual helps
    • rightbrained
      • Oct 2014
      • 40
      Very helpful. Thank you.
