Swap Battery from MFPB Board on bizhub C-224e Series
  • CP-1015
    • Nov 2020
    • 306
    How to change the battery on the MFPB board without junk? Can the battery be removed after disconnecting the SSD? Thans advanced.
  • wjurls
    • Feb 2017
    • 492
    Re: Swap Battery from MFPB Board on bizhub C-224e Series
    It's been suggested somewhere on this site before to solder a new battery in parallel with the old one first, then cut the old battery out of the circuit.
    This is a good strategy to avoid wiping out the memory.
    • CP-1015
      • Nov 2020
      • 306
      Thank you!
      • Gift
        • Mar 2011
        • 2455
        Yes absolutely bypass the old battery with a new one before cutting it off so the MFP board is provided with battery voltage at all time. Are you perform this as a precaution?
        • CP-1015
          • Nov 2020
          • 306
          Yes, for batteries with 3 or less volts voltage.
          • Gift
            • Mar 2011
            • 2455
            Good thinking - we also have a look if the MFP is considered not to be swapped in a foreseeable timespan.
            There's a lot of refurbished Cxx4e out there, it's important to check them because we weren't aware about this at the time of refurb&reselling.
            • CP-1015
              • Nov 2020
              • 306
              It would be interested to know from which memory the data is lost, because the SSD and memory board/1 can be safely unplugged. After all, it is a PC motherboard.
