Help configuring card reader
  • luis.elias
    • Mar 2019
    • 5
    Hello everyone,
    I'm currently experiencing some issues while configuring an HID 5427CK card reader on a Konica Minolta C308. It seems that I need the Auth Device Tool Advanced in order to proceed with the setup. I already have the ICC_LDR.tar file.
    Does anyone know where I can download this program?
    Thanks in advance!
  • kingarthur
    • 1351
    Silly question - have you turned the card reader on in the tech rep mode
    • luis.elias
      • Mar 2019
      • 5
      thanks for you repply kingarthur, yes i did but no success. This is what o got from the manual:
      h) Auth Device Tool Advanced for 5427CK (Setting IC card information in the loadable driver in advance: TypeA/
      HID Prox/Multiple)
      NOTE
      ▪ Selecting [Multiple] makes cards of HID Prox, HID iCLASS and TypeA available at the same time.
      1. Obtain the loadable driver (ICC_LDR.tar) for use in OMNIKEY 5427CK (AU-205H) that is compatible with the type of card used.
      2. Start the Auth Device Tool Advanced for 5427CK (AU-205H).
      3. Select card type. (Except for HID iCLASS)
      4. Select Loadable Driver in [Export Format] and click [Export].
      5. Select the loadable driver to be updated and the output location of the loadable driver and click [OK].
      6. Copy the output loadable driver (ICC_LDR.tar) to the root directory of the USB memory.
      NOTE
      ▪ Please do not save any other data in the USB memory.
      7. Call the Service Mode to the screen of the MFP.
      8. Select [System 2] -> [Driver Install] -> [Install].
      9. Connect the USB memory in which the loadable driver has been saved to the USB port on the side of the control panel.
      10. Select [Loadable driver] and touch the [Start] to install the loadable driver.
      11. Remove the USB memory and, accessing [Billing Settings] -> [Authentication Device 2], select [Card].
      12. Turn OFF the main power switch, wait for 10 sec., then turn the switch ON.
      13. Set the authentication user.
      • kingarthur
        • 1351
        If I remember correctly KM in the UK (EU) loaded all of their card drivers etc to a filezilla which you need an SFTP ( none of which means anything to me ) to access/download we only use YSoft card readers, of which we downloaded all of the drivers ages ago. Maybe contact KM in your area to see where/how you can access the tool.
        • luis.elias
          • Mar 2019
          • 5
          I was hopping if someone could send me this Auth Device Tool Advanced sofware.
          If anyone has worked with papercut e could help me to find out whats happening. Ive already installed the card reader driver "ICC_LDR.tar" wich is a OMNIKEY 5427CK. In the machine display shows swipe card, when i dot, it beeps but nothing happens.
