Bizhub 808 - C-FA 14
  • krm
    • Aug 2009
    • 233
    Hello~
    Tried unsetting HDD (waiting on a new HDD), resetting code several times, replaced main board and newest firmware. Machine still won't clear the code. Anyone had this?
    Thank you in advance.
  • tsbservice
    Field tech
    • 8020
    Re: Bizhub 808 - C-FA 14
    Did you disconnect HDD together with disabling it?
    • Synthohol
      Certified Konica Expert
      • 5847
      Problem
      When PaperCut is installed with U8 or higher firmware the following issues may occur.
      • CFA14 error code
      • Card Reader is unable to authenticate
      • The PaperCut Application is removed from the device since the IWS on the device crashes
      • Http Transport error reported on PaperCuts Log.
      Solution
      CAUSE: Firmware requires updating.
      SOLUTION: Install the following firmware version depending on MFP.
      • bizhub 808/958 - A7950Y0 - F000 - GG7-W5
      Problem
      Insufficient Memory message, also CE301 or CFA14 error codes.
      Solution
      CAUSE: Problem causing CE301 by operation of screen transition of browser application. Problem with CFA14 caused by repeated operation of launching OpenAPI application / MFP standard function(copy etc) from IWS application
      SOLUTION: Some Special firmwares are available: GG1-R9 should resolve both these error codes.
      If CFA14 is not resolved then update to GG6-R9 which is available for most models in this series, should be available for the other machines by end of March 2018 .
      C-FA14 or C-D**
       Connection failure of HDD
       HDD failure
      thats all i got.
