Bizhub C754e PRO ligh line on tick paper only
  • Sandoval
    • May 2018
    • 12
    Hello,
    I have bizhub C754e on 800K counter with Fiery controller. The printer issues a light line on Tick paper only. Checked with other fusing unit, transfer belt unit, transfer roller, but no solution. On halftone test pages no any light lines. Only on tick4. The line is on the paper's path.
    First 3 counts are ok. The line appears after 3-4 counts.
  • tsbservice
    Field tech
    • 7910
    Re: Bizhub C754e PRO ligh line on tick paper only
    Checked with another good brand thick paper?
      • 22929
      Can you describe this "Tick" paper as gsm? Is it set to the correct media type for that gsm?
      Try these images. What colors are affected?
