CE Password Reset Request for bizhub C3300i
  • a7mad-989
    • 16
    Hello everyone,
    I need help with generating a CE password reset code for a Konica Minolta bizhub C3300i.
    Here are the details from the machine:
    - Printer Serial Number: AAJT021203934
    - MAC Address: 00:20:6B:4E:2DC
    - CE Password Reset Request Code: KUL73-EYPQY-9TF22-NJF6P-8P63E-CG8YD-ENJQG-4ZTBB
    I've tried default passwords like 92729272 , 12345678 and 00000000 but none of them worked.
    The local dealer is not responding, and I need to reset the CE password to perform maintenance.
    Any help or reset code would be greatly appreciated!
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5883
    post here instead for best results.
    https://www.copytechnet.com/forum/te...48#post1627171
    • a7mad-989
      • 16
      okay thanks
      • JMS
        • Apr 2023
        • 30
        Did you try 92729272 or 9272927292729272? The length ist 16 chars, not 8.
        • a7mad-989
          • 16
          thanks for replay,,i try all but not work
          • otphas
            • Aug 2019
            • 125
            C3300i is with microSD card, just format the card and install new firmware. The printer will make recovery and will come default pass.
            • a7mad-989
              • 16
              how,,,can you explain please
              • otphas
                • Aug 2019
                • 125
                Open the back cover and on CPUIPB you will see microSD card take it out connect with any adapter to your PC format it, than install back to your machine and start the machine with firmware update usb stick.
