Bizhub C-458 A79J0Y0-F000-GC5-X8
  • CP-1015
    • Nov 2020
    • 323
    Above machine shows at MFP Card Version:
    2,ID=000000,NM=000000,OP=0S. Is it correct? Thanks advanced.
  • tsbservice
    Field tech
    • 8052
    Re: Bizhub C-458 A79J0Y0-F000-GC5-X8
    Should last on ..... GC5-X8
    What's the problem?
    • CP-1015
      • Nov 2020
      • 323
      What's the problem?
      I've never seen that: 2,ID=000000,NM=000000,OP=0S. And it's not possible to read unitstatus per SNMP - only toner and wast toner box.
      • tsbservice
        Field tech
        • 8052
        Originally posted by CP-1015
        ... And it's not possible to read unitstatus per SNMP - only toner and wast toner box.
        soft switches 227 and 230 set them to 00...good luck
        • Synthohol
          Certified Konica Expert
          • 5892
          Hit utility and device information. Scroll down for the fw version installed.
          • CP-1015
            • Nov 2020
            • 323
            There it's the same:
            • tsbservice
              Field tech
              • 8052
              As a bonus you can see also function version. Since I started on KMs few years ago I rarely ever check FW versions in CE mode.
              Maybe only on older models or when machine behaves erratically.
              • CP-1015
                • Nov 2020
                • 323
                Thank you! After switch 230 to 00 function as usually.
                But what's the meaning of "2,ID=000000,NM=000000,OP=0Sum"?
