Konica AP C3070 Scan button grayed out
  • qaraman
    • Oct 2019
    • 21
    [Misc] Konica AP C3070 Scan button grayed out
    The scan button on the top right corner of the screen is grayed out and I cannot access the scan functionality; we had the scan running before but now is suddenly grayed out.
    I have checked DIPSW 2-0 and 18-7, all normal. I have checked that the scan store mode is not set to HDD so I'm quite certain that the HDD is not full.
    Any other ideas?
    Thanks,
  • copytechman
    • Nov 2008
    • 954
    Any other ideas?
    Thanks,
    Scanning is often tied to type of controller installed, does it have the IC controller or a Fiery?
    Regards
    A.
    • qaraman
      • Oct 2019
      • 21
      Hi
      It is installed with IC-605A.
      Regards
      Sami
      • copytechman
        • Nov 2008
        • 954
        Hi
        Regards
        Sami
        This will sound dumb but is the following dipsw set correctly?
        40-7 IC-605 controller connection (Default settings for
        C3080, C3070, C3070L: 1, for C3080P, C83hc,
        C3070P, C73hc: 0)
        · Function: Switches the connections of the KM
        controllers and the outsourced controllers.
        · Usage: Select "0" on this setting when you
        connect IC-313, IC-314, or IC-417. Select "1"
        when you connect the IC-605.
        • 0: Not connected
        • 1: Connected
        Regards
        A.
        • qaraman
          • Oct 2019
          • 21
          Yes it is correct I just checked it. the machine prints perfectly fine, but only scan button is grayed out.
