458 Protocol Errors
  • splblazer91
    • Jul 2014
    • 204
    458 Protocol Errors
    Knowledge Base was no help. Have Changed multiple settings in SM to no avail. Initalized fax as well.
    Can send all day long just fine. When receiving a multii page fax it will usually fail halfway through and delete. It will retry and complete the job.
    A machine 15ft away receives faxes just fine.
    Any ideas?
  • copier tech
    • 8299
    Re: 458 Protocol Errors
    Any ideas?
    Update the firmware.
    Also check the fax line is good. Any crackle etc on the line will cause the fax to fail.
    • tsbservice
      Field tech
      • 8151
      Temporary move the machine to one next to it and use working fax line to see how it goes.
      • Gift
        • Mar 2011
        • 2456
        I agree, try and hook the machine to the other fax line and see what happens.
        If you can transmit without problem but won't receive (with the same destinations) I think it's not a problem with the FK514.
