MINOLT BIZHUB C360 alignment problem on color prints
  • tecnomarco
    • Jul 2011
    • 214
    hello to all I have a problem on prints and color copies of yellow color alignment .... it creates a double line for me a "line position problem ... in assistance mode how can I correct this, can you tell me the simulation to do? in assistance mode..thank you I have attached some prints
  • davidj7
    • 1107
    Re: MINOLT BIZHUB C360 alignment problem on color prints
    are you using compatible drums?
    did it happen just all of a sudden or after drums were changed?
    in service mode ->stabilization should fix it
    a machine is only as good as your tech : source:screwtape ; the scary one
    • tecnomarco
      • Jul 2011
      • 214
      Thank's David ...yes I use drum compatible but I have change only drum black, not colour..
      • tecnomarco
        • Jul 2011
        • 214
        they are complete compatible drums not regenerated by me
        • tsbservice
          Field tech
          • 8020
          Color registration is based on K(black) so...
          Remove ITB and clean IDC sensors (x2) then as suggested make stabilization.
          By the way this compatible drum does it have new chip?
          • tecnomarco
            • Jul 2011
            • 214
            Thank's I will do as you say
            • occus
              • 337
              I see a little skew on yellow...
              Clean IDC Sensors, go first in machine>print head skew adjustment>print head skew adjustment reset 2x and make the stabilization and gradations adjumstments.
              I think it's important to have a black drum in good conditions.
              • tecnomarco
                • Jul 2011
                • 214
                Thank's occus i change the new drum black but can you explain to me this simulation....machine-print head skew adiustment....ecc
