Konica Minolta 6501
  • kseyhan
    • Mar 2022
    • 6
    [Misc] Konica Minolta 6501
    Hi there;
    I have a Konica minolta 6501 machine, and I get a lid open warning. When I remove the finisher, the machine heats up all the time, it does not switch to the ready state, the problem is the reason. Can you help me
  • orestesp
    • Sep 2019
    • 222
    Re: Konica Minolta 6501
    So your issue is that the machine isn't warming up (hangs at "Machine is warming up - Please wait") and never reaches the "Ready to print" status?
    Is anything obvious amiss with the fuser? Do you get a C-3xxx code maybe?
    • 907tec
      • 434
      IIRC, this model can sometimes have one of the two fuser lamps die without ever triggering a code. It will sit in the "warming up" stage forever. Try to take a peek and see if both lamps are coming on.
      • Synthohol
        Certified Konica Expert
        • 5806
        Problem
        "Now warming up" message remains on the display.
        Solution
        PROBABLE CAUSES:
        1. One of the heat lamps has failed.
        Use an ohm meter and check each of the 3 upper lamps (p/n A03U M31E 00) and 1 lower heat lamp (p/n A03U M32E 00) for continuity. If any fail the test, replace the lamp.
        2. PWB-PRCB has failed.
        Replace the PWB-PRCB (p/n A03U R7B5 00).
        • kseyhan
          • Mar 2022
          • 6
          yes, it constantly says "machine is warming up, wait" and it doesn't go to ready mode. no error message appears on the screen.
          • kseyhan
            • Mar 2022
            • 6
            Originally posted by Synthohol
            Problem
            Solution
            PROBABLE CAUSES:
            I did a visual check and did not see the lower lamp illuminated. I will also check with voltmeter. I will let you know
            • kseyhan
              • Mar 2022
              • 6
              I checked the lamp and saw that it was intact. What is the next step? Could there be a problem with the gears? When I turn on the machine, the oven does not rotate while it is warming up.
              • Synthohol
                • 5806
                you checked all 3 lamps with an ohm meter?
                • 3ktlc
                  • Feb 2018
                  • 180
                  Need to check with an ohm meter. just because it looks intact doesn't mean it is good. Used to see this years ago on the old 7090's.
                  • kseyhan
                    • Mar 2022
                    • 6
                    Aren't there two lamps in the oven unit? yes i checked with ohm meter value:8
                    • tsbservice
                      Field tech
                      • 7982
                      Must be 4
                      Clipboard01.pdf
                      • tulintron
                        • Jul 2014
                        • 668
                        There is a one way below the pressure roller. You can substitute for the bottom part of the fusion if you have technical skills.
                        When it fails, it has the same problem as yours.
                        • kseyhan
                          • Mar 2022
                          • 6
                          I checked all the lamps and they are working. printer still not working
                          • hinbox
                            • Jul 2014
                            • 22
                            Check your bushings in fuser rollers also.
                            • Toxic
                              • 697
                              I would check phisically all fusing sensors and temp readings in service mode.
