BH-C-284e, faxoption
  • Hansoon
    • Sep 2007
    • 3391
    I just installed for the first time an FK-511 fax kit. Machine seems to operate but what I am missing is the fax monitor sound over the speaker as I know from previous models. This BH-C-284e has two speakers. What could be the reason that at least one of them is not working as a fax monitor? What did I miss?
    Hans
    • 14972
    Re: BH-C-284e, faxoption
    Hans
    Go into admin mode. Select fax settings, line parameter settings. Page two and select line monitor.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4765
      Make sure the country code is correct!
      • tsbservice
        Field tech
        • 8053
        Like ca already said:
        • [Utility]
          • [Administrator Settings]
            • [Fax Settings]
              • [Line Parameter Setting]
                • [Line Monitor Sound]
        Select whether to monitor sounds on the telephone line during fax communication.
        [OFF] is specified by default.
        Descriptions of Functions / Utility Keys
        • Gift
          • Mar 2011
          • 2459
          You should hear something if you press the phone-handset icon on the top/left of the screen and dial some numbers. I think other line sounds are disabled by default and can be enabled as already described here,
          • Hansoon
            • Sep 2007
            • 3391
            I previously set up the system correct already as you describe but since everything looks so much different than before and it was the first time I did it in this generation of machines I expected some set up mistakes from my side with this Stone-Age technology.....
            Seems that the speaker is not operative. Will have a look on Saturday for it. Thanks for you help guys.
            Hans
            • Hansoon
              • Sep 2007
              • 3391
              Re: BH-C-284e, faxoption ***SOLVED***
              Yes, indeed it was the front speaker. Some dork (me?) left the harness unconnected.
              The solution is so simple I should have found it out myself. I was just expecting unusual set up procedures unknown to me.
              Thanks guys and have a nice weekend.
              Hans
