Bizhub C258 numerick keypad in admin
  • lebo
    • Aug 2012
    • 88
    Hello,
    I have such a strange problem In administrator mode (Bizhub C308). Numerick keypad does not open when I want to input numbers in any time. For example during configuration network or power save time. Keypad button (again only in admin mode) does not work as well.
    I do not know the history of this machine, my new customer bought it as a refurbished machine from abroad. I upgraded firmware by localizated version (and od course set recomanded function version) but it does not resloved this problem.
    Do you have any idea how to fix it ?
    Thank you.
  • tsbservice
    Field tech
    • 7930
    Re: Bizhub C258 numerick keypad in admin
    I would go for Clear All data(Initialize) machine.
    • Synthohol
      Certified Konica Expert
      • 5749
      Was a keyboard or ldd driver or card reader attached? That will do it too.
      If you can get into service security mode turn off vendor mode.
      Or plug a USB keyboard in and see if that let's you enter the password for admin mode.
      • tech51
        • 846
        Check the usb settings in admin/security. Maybe external keyboard is switched on…
