C6500 different lines at the all colors
  • GrayEminence
    • Apr 2018
    • 6
    Hi, I ran test pattern #53 with 120 density and I saw that there is a problem when I see light horizontal lines in the feed direction. I am adding a photo.
    Drums and developers have been recently replaced.
    Any tips?
    Thank you!
    • 23008
    Re: C6500 different lines at the all colors
    And how did the primary charge units look? =^..^=
    • GrayEminence
      • Apr 2018
      • 6
      Did you mean charging coronas?
      • tech51
        • 846
        Either clean or (preferably) replace the coronas. Also make sure your transfer belt is in good condition.
        • hinbox
          • Jul 2014
          • 22
          That is def. corona wires try replacing or clean with alcohol and microfiber towel. Blue paper towels might make it worse.
          • GrayEminence
            • Apr 2018
            • 6
            Thank you all! I bought new coronas and the problem was solved!
