Konica Minolta bizhub C368 C-9401
  • Techman63
    • Mar 2022
    • 10
    [Error Code] Konica Minolta bizhub C368 C-9401
    Hi dear Everybody !
    I hope all are fine.
    Hopefully, somebody can you help me.
    My C368 has a C-9401 code. I prit out the management list. The machine had earlier sometimes this code and C-9402 too. But since friday the code 9401 is permanently.
    I changed the LED Exposure Unit with Flatban Cable, Scanner Drive Board, CCD Unit with cable without succex. I tried to upgrade the firmware, nothing.
    Does have anybody idea?
  • tsbservice
    Field tech
    • 8031
    Re: Konica Minolta bizhub C368 C-9401
    Originally posted by Techman63
    Hi dear Everybody !
    Does LED unit light at all?
    • kingarthur
      • 1380
      have you carried out a trouble reset after replacing any parts
      • Techman63
        • Mar 2022
        • 10
        Yes, it is.
        It is moving in the right home position and in the shading position and light.
        • Techman63
          • Mar 2022
          • 10
          Yes I did. With front cover and with trouble reset too.
          • Techman63
            • Mar 2022
            • 10
            Hi everybody!
            I solve it!!
            DC Power Supply has a direct cable contact for the scanner drive PWG, especially a 12V for the CCD Unit. This pin had a contact trouble on the DC Power PWB. Horrible. I have it repaired and all right after that.
            Thanks the comments and see you for all.
