Konica 958 printing "zigzag" lines on barcode
  • PSO Software Support
    • Apr 2022
    • 1
    I have a customer using a Konica 958 printer that is printing some barcodes with distorted bars / images.
    This started 2 weeks ago. Multiple barcodes are sent in a single print job and only 1 of 20 barcodes prints this way.
    Can anyone offer suggestions as to what may be causing this issue and what we can try to fix it?
    Thank you in advance.
    • 23007
    Re: Konica 958 printing "zigzag" lines on barcode
    I'd think about the laser, though I must say that I've never changed a Minerva SBK laser before.
    If you have another fuser you can try in there, do that first. I was reading about a Kyocera the other day with zig-zag lines of print, that was caused by an upper fuser roller bias contact. =^..^=
    • Lordnixon
      • Jul 2017
      • 18
      Remove and install the latest drivers
      • allan
        RTFM!!
        • 5462
        Looks like a type of moire effect. Wonder if its because of multiple lasers. If that's the case then its caused by the engine and a hardware effect. Wonder if a LPH would cause that.
        Not sure if using different driver would make a difference. If using PCL try PS and visa versa.
        Had this kind of thing on the pro 950 machines.
        Is this causing issues when scanning the barcodes?
        Whatever
