Hello, kindly can someone suggest me how to clean oven film for konica minolta c284e. Thank
Konica minolta c284 oven film
Blessed are they who can laugh at themselves, for they shall never cease to be amused. -
Re: Konica minolta c284 oven film
I'm assuming you are talking about the "fuser" film. If there is some baked on toner this can be removed very carefully with what the others suggested. Most likely will return. Also have to take into account what the page count of copier / consumable life is. Keep in mind even if a lower page count the C284 is now around 10 years old and if original fuser has been subjected to extreme heat & pressure all those years.Comment
The film and roller are available as aftermarket parts and much less $$ then buying new fuser. I've had great success with rebuilding the units. But the fuser unit is not easy to rebuild and would only recommend for technicians to attempt it!Comment
i'm assuming you are talking about the "fuser" film. If there is some baked on toner this can be removed very carefully with what the others suggested. Most likely will return. Also have to take into account what the page count of copier / consumable life is. Keep in mind even if a lower page count the c284 is now around 10 years old and if original fuser has been subjected to extreme heat & pressure all those years.Comment
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
