DTP Setting
+ More Options
Posts
  • stan780953
    • Feb 2011
    • 47
    DTP Setting
    Hello,
    I have been using the DTP quality setting for some time now on the 4/8 series as a bit of a get out of jail option when customers are complaining about colour matching issues and don't want to spend Money on a fiery, but for some reason this option has been removed from the i range. Is there anyone else out there missing this option or have any tips?
    The reason I ask is I'm struggling to get a C250i to print the same colour as a 4 series, even after changing SW153.
    Thanks.
  • mojorolla
    The Wolf
    • 2630
    Re: DTP Setting
    • Synthohol
      Certified Konica Expert
      • 5888
      Re: DTP Setting
      if the customer requires pantones and color matching then a Fiery is a must.
      the standard emperon controller is WYSIWYG.
      out of the box the copier is considered business color, not a bloody printing press
      • stan780953
        • Feb 2011
        • 47
        Re: DTP Setting
        [ATTACH=CONFIG]53150[/ATTACH]
        [ATTACH=CONFIG]53151[/ATTACH]
        Thank you for the info - I have tried both but can't get near the output from the 8 series.
        • stan780953
          • Feb 2011
          • 47
          Re: DTP Setting
          I understand where you are coming from, but from the customer's point of view their last two copiers(4/8 series) were fine so it's all about trying to find a happy medium and let's face it we all know they are considered business colour but in reality, the customer will push the copier to its limit because they can produce a decent print without spending the extra for a fiery.
          • mojorolla
            The Wolf
            • 2630
            Re: DTP Setting
            Without a true color matching system, you are very limited on color matching. The only other settings you could tweak would be in the print drivers. See below:
            Are you familiar with the color gamut?
            • strider5555
              • Jun 2008
              • 96
              Re: DTP Setting
              You could also try this setting, though KM does not specify what this switch does. I have not tried it myself.
              • Max
                • Oct 2011
                • 566
                Re: DTP Setting
                In my opinion, the I series has been a tad castrated on colour quality because the previous generation was so good and not a million miles from dare I say a pro range. Pure Business decision. As mentioned before. It's only an office colour after all.
                • emujo2
                  • Mar 2017
                  • 1579
                  Re: DTP Setting
                  I have to take Stans side on this one...I have a lot of customers that are disappointed (at best) and "take the damn thing back" at worst..There is a noticeable difference between the e/8 and I series..In many cases these setting are enough. The colors are " blaugh " when put side by side..It's not like they are going from a Toshiba to a KM product..The output should at least be in the ballpark of the old machine and IMHO better. E
                  • Scope
                    • Feb 2022
                    • 16
                    Re: DTP Setting
                    Give this a Try
                    Colour Tone i series.pdf
                    • tsbservice
                      Field tech
                      • 8049
                      Re: DTP Setting
                      Originally posted by Scope
                      Give this a Try
                      [ATTACH]53185[/ATTACH]
                      Already suggested by mojorolla
