ERRORE D3A0
  • CIRO
    • Apr 2020
    • 33
    ERRORE D3A0
    Good evening, I replaced an ssd for konica minolta 554e used on a 364e but it gives error D3A0, HOW CAN I SOLVE THE PROBLEM.
  • tsbservice
    Field tech
    • 8020
    Re: ERRORE D3A0
    SSDB on these machines is cheap enough, go get new one not used.
    • zoool
      • Nov 2016
      • 52
      Re: ERRORE D3A0
      hi. upgrade the firmware. this helps you
      • Synthohol
        Certified Konica Expert
        • 5847
        Re: ERRORE D3A0
        I would double check the machine and type booting to a firmware stick
        Change it to what it's suppose to be for that model.
        It's prolly telling the boards it don't belong
