KM C3350i and duplex print from linux cups
  • i-have-fax-problems
    • Mar 2020
    • 106
    I've installed the ppd for C3350i on a linux system.
    I simply can't find where to active the duplex unit.
    The 1-sided 2 sided button in my app (libre office) remains grey.
    I cant select 1 or 2 sided. I've searched through cups. I can't find something
    like Duplex Unit installed or uninstalled.
    What I do wrong?
  • Synthohol
    Certified Konica Expert
    • 5838
    Re: KM C3350i and duplex print from linux cups
    Set Mac Print Driver to Default to 1 Sided on Bizhub MFP - YouTube
    does your cups look similar?
      • Mar 2020
      • 106
      Originally posted by Synthohol
      Thank you.
      There is the button "Print Type" under "admin" then "finishing" too where I can switch from 1-sided two 2 sided,
      but in the application (Libre office in this case but with other apps there is the problem too) the 1-sided 2 sided button
      remains grey. You can't switch it.
        • Mar 2020
        • 106
        Thank you,
        KM Support gave us another ppd, which solved the problem.
        Seems the ppd you can download from km website has this bug.
        • anony253
          • Feb 2024
          • 1
          Originally posted by i-have-fax-problems
          Thank you,
          Any chance you can share these files ? We have the same problem, CUPS just plain refuses to change printer to 2-sided mode
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            While it may be best to get an "approved" ppd from KM, you can always try OpenPrinting - OpenPrinting , as they have quite a few ppds available.
            I have used them quite a few times for ppds that I've used in Mac, Linux, UNIX, and even Windows.
