Konica C308 error FA-14 and E3-01
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    Can anyone help with errors FA-14 and E3-01 on a c308?
    I'm on the understanding that the firmware needs updating or the HDD needs formatting or replacing...
    TIA
  • femaster
    • May 2011
    • 1514
    Re: Konica C308 error FA-14 and E3-01
    Those codes were addressed in firmware updates quite some time ago. I guess you'd need to check and see what the current firmware version is before making a determination as to what the cause is.
    • tmmdmmm
      • Apr 2021
      • 173
      "e301 occurs when..." is in literally every FW's PDF. Are these codes on startup or while printing specific documents?
      Unplug the ethernet and do a trouble reset. If it doesn't show its network traffic and I haven't had experience with that, our IT has (I have seen it caused by a specific document, printing page 3 in a PDF would code).
      I've had it show on startup and firmware didn't fix it. I didn't have a drive on me but doing a clear all data followed by a logical got rid of the code, its been about a year and still running fine.
      If it occurs without ethernet disable the Hard drive in service mode and unseat the connections. You'll lose scanning capabilities but should still be able to print. That'll confirm its the drive. With FA14s in there as well I imagine its the drive, but go ahead and check with the drive disabled
      • femaster
        • May 2011
        • 1514
        Exactly my point. You can't pinpoint the cause of the problem unless you are running the latest firmware to know that all the previous causes that are firmware related have been fixed first.
        • tsbservice
          Field tech
          • 8030
          That's some very good logic tmmdmmm. Plus latest firmware of course.
          E301 is KM dreaded error and not an easy to troubleshoot.
          • jonbonse
            • Jun 2009
            • 737
            Well, I attended site and found the HDD set to not installed and the IP set to manual with the generic 169.x.x.x....
            Weird, so I set the HDD to installed, upgrade firmware, then setup correct IP settings then and the machine was back to normal.....
            Maybe IT connected remotely and done some reset? I dunno....I changed the Admin password anyway just incase
            Thanks for all the input!
            • tsbservice
              Field tech
              • 8030
              Yep sounds like an 'advanced' customer's job - doing network reset and HDD format not knowing how it works.
