Read data from MFP!
  • CP-1015
    • Nov 2020
    • 321
    #16
    Re: Read data from MFP!
    Now, bizhub C-754 is tested, too.
    • emujo2
      • Mar 2017
      • 1579
      #17
      Can anyone who is helping him please explain in English what he is trying to do and what his report is supposed to do?
        • 23008
        #18
        The way I understand it, this software gathers Management List data like consumable life and counts, for the purposes of evaluating a used machine for possible purchase.
        The only benefit I see to this software is to gather data from a printer in an unable-to-print error condition.
        This data can easily be reset or spoofed (reset chips) without changing parts, so ... without actually looking at the consumables & print quality, I don't see how it helps evaluating the machine very much. You may catch obviously past-life consumables. That's about it. =^..^=
        • CP-1015
          • Nov 2020
          • 321
          #19
          The only advantage: It works automatically within 20 seconds! Every wholesaler has to label his machines (PDF file and print automatical) and he needs a list (automatical file):
          The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
          For wholesaler it's only one version. I'm no official KM Dealer. I have no access to their software - so I have to make my one.
          • CP-1015
            • Nov 2020
            • 321
            #20
            Got today new from a hardworking helper:
            bizhub 367
            4050
            4052
            Ricoh IM C3000
            Thank you very much.
            The software newmodels is only for me to understand data construction. It reeds about 6-7000 values. For seeing consumables life by KM machines software switch 227 set to hex 00. For comparison I need counter-, consumables- and accessories list, too.
            From KM I need speziale C-250i
            C-3350
            C-3350i
            Whether C-250i or C-300i or C-360i is irrelevant. Thanks advanced!
            • CP-1015
              • Nov 2020
              • 321
              #21
              When checking whether my program is compatible with the bizhub 4050, the question about the content of the maintenance kit pops up
              on.
              • derrekflo
                • Feb 2022
                • 40
                #22
                I can help with some models
                • CP-1015
                  • Nov 2020
                  • 321
                  #23
                  That's great. What models? Thanks advanced.
                  • derrekflo
                    • Feb 2022
                    • 40
                    #24
                    Ricoh Mp402
                    Ricoh Mpc 5503
                    Ricoh Mpc 6502
                    Konica minolta Bz C654
                    • CP-1015
                      • Nov 2020
                      • 321
                      #25
                      Ricoh Mp402
                      Ricoh Mpc 5503
                      Ricoh Mpc 6502
                      Hello,
                      thanks for your help.
                      bizhub C-654 maybe the same like C-754 but the Ricoh modells are very interest.
                      Here are the WeTransfer links
                      Documentation: https://we.tl/t-L82yERfdjs
                      newmodels.exe: https://we.tl/t-NUJXOw9C0Z
                      IP.txt: https:https://we.tl/t-PIXyCEzAQo
                      If any missfunktion please send me PM.
                      Best regards
                      • CP-1015
                        • Nov 2020
                        • 321
                        #26
                        Thanks for a helper which delivered data from
                        KONICA MINOLTA bizhub PRO C1060L.
                        • CP-1015
                          • Nov 2020
                          • 321
                          #27
                          Thanks to jotunn! Thanks to him I was able to rewrite the actual program (newmodells is only for learning the data structure) so that it works for all Minolta models. Now other brands are interesting. For example, whether identical Olivetti models have the same data structure. I also turn to the individual brand forums. I also need counter and status lists for assignment.
                          If anyone else wants to help, please message me for a new link to "newmodels". I ask you to respect the copyrights. Thanks!
                          Many thanks in advance for your help!
                          • techsxge
                            • Jan 2022
                            • 660
                            #28
                            Olivetti has the same data structure. The only actual difference is that it says Olivetti instead of Konica Minolta on the front. Some Machines even have KM address printed on the back right above the power plug
                            I'd like to get the new version if possible
                            • CP-1015
                              • Nov 2020
                              • 321
                              #29
                              Really? I found small difference between KM bizhub C-224e and Develop ineo+ 224e. It's no problem, but Olivetti machines are not all indentical to KM machines, some are only similar. And for excample D-Copia 4000/5000MF seems not form KM. It would be great, if you could help.
                              Edit: For excample the Olivetti models from C-250i Series have another drum unit. It would be interest if the data structur is identical.
                              • techsxge
                                • Jan 2022
                                • 660
                                #30
                                OK i have not compared all KM Machines to the Olivetti Counterpart as i am not a KM Dealer but Olivetti. But for the main office machines i have not seen any differences except for the hardware coded parts.
