Konica Minolta C280 No Display - Power and Start Button Lights are on
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C280 No Display - Power and Start Button Lights are on
    konica Minolta C280. The main power is still on in the machine but its like the power switch near the lcd on the right hand side has been turned off. But if you do press that button tge light near it goes orange then when you press it again it goes blue, but nothing comes back up the screen still black.
    Please advise.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4545
    Re: Konica Minolta C280 No Display - Power and Start Button Lights are on
    Solution
    PROBABLE CAUSES:
    1. NVRAM is not securely installed.
    Reseat the NVRAM.
    2. MFPB (PWB-MFP assembly) failure.
    Replace the MFPB board (p/n A0ED H020 06 for the bizhub C280/C360 and p/n A0ED H021 02 for the bizhub C220).
    Also check that memory mods are seated.
    PM me if you need anything for this model. I have 2 working machines that will part out.
    • zoool
      • Nov 2016
      • 52
      try to change dimm memory. it's help me
      • ck1
        • 485
        same with C253 ?
        • zoool
          • Nov 2016
          • 52
          Originally posted by ck1
          same with C253 ?
          noo only c220 series and 223 series have that same dimm
          • Hansoon
            • Sep 2007
            • 3354
            If you cannot find them, PM me. I have here in Germany several still in stock.
            Hans
            “ Sent from my Intel 80286 using MS-DOS 2.0
            https://www.copytechnet.com/images/smilies/biggrin.png
