Software for scan
  • Tiagocang
    • Feb 2022
    • 62
    Software for scan
  • femaster
    • May 2011
    • 1514
    Re: Software for scan
    Since it's a single, smaller item they are looking to capture, I'd assume that it doesn't need to be a PDF. If that is the case, and they are on Windows, they could do it without any additional software.
    Just have them scan in whatever it is they want in whatever size the copier the makes it. Assuming the copier scans it in as a PDF, open the scan in whatever PDF viewer they normally use.
    Next, open up the built-in piece of software in Windows called Snip & Sketch. Click the NEW button, then they can draw a box around whatever the smaller portion of the scan is they want.
    That don't need to be exact when creating the box, as Snip & Sketch can further crop the image down to exactly what they are after, and then can save it in various image formats.
    If they really want to have it as a PDF, they can use the built-in Microsoft Print to PDF right from within Snip & Sketch.
    • Tiagocang
      • Feb 2022
      • 62
      But client only wants to scan that piece he said loses quality scanning all page then cut only the photo
        • 14813
        He could change the "original size" setting to match the size of the image he wants to scan.
        • emujo2
          • Mar 2017
          • 1579
          Scan the image as a .Jpeg..then use the workstation to crop..I believe you might be able to do this by fooling around with the non image settings, but why go to all that trouble??
          • zayonc
            • Jan 2022
            • 49
            The installation DVD with the driver contains utilities that are installed separately. They have a TWAIN scanner that allows you to scan from a computer with all the conveniences.
            • Tiagocang
              • Feb 2022
              • 62
              Is it hard to configure twain scan? Never tried that
              • zayonc
                • Jan 2022
                • 49
                very simple
