с6000l with 4661 error code
  • schlf
    • Feb 2022
    • 18
    After replacing the developer I got a whole bunch of problems although all the adjustments were passed and done quality wasn't quite good. Checked the cleaning unit of the ITB and the belt itself and both were ok, Cleaned the IDC sensors but still err 2 on color autimatic adj, and the machine doesn't pass gamma auto adj. Running I / O Check mode 36-3 / 36-4 / 36-5 found out one of the idc sensors (the far under the code ..-05) showing 0 in output value and that's where i got completely stuck. If you guys have any thoughts where to get the sensor from or what to do I'd really appreciate that/
  • Toxic
    • 698
    Re: с6000l with 4661 error code
    More info would be helpful...
    Machine counter, parts life counter (drum, developer, charge unit...)
    Did you follow procedure from service manual ?
      • 23009
      I've seen those IDC sensors bad before. Also check that the shutter is opening up far enough for the sensor to see the transfer belt. If that mechanism gets bent (and it does), the shutter opens only 1/2 way. =^..^=
      • schlf
        • Feb 2022
        • 18
        I'll check the shutter opening gate. That started after developer replacement, aut developer charge was donw, automatic color registration was done, automatic gamma adj was also done and few prints but the quality was poor and the problem stated with a laser error 53-01 i believe, but then it was gone, lasers can adjust itself. and then a parade of IDC errors
        • Toxic
          • 698
          If you did not run Toner density init first after developer replace that could be your problem.
          • wjurls
            • Feb 2017
            • 498
            Seen this a few times. You can reach in and manually tape the shutter open for testing purposes. Color registration sensors do go bad also. Just had to order one myself for a Accuriopress C2060. This is the second Color Registration sensor I've had to replace on the C1060 series. C6000 is similar.
            Run the density balance chart and insure that yellow looks dense enough for sensors to read. If it isn't, look into developer, drum, transfer issues first. 1st transfer rollers inside belt unit can sometimes come out of position. If the CR sensors are bad, or the shutter, it will always throw the code for yellow. It won't be any other colors as it stops after yellow.
            • schlf
              • Feb 2022
              • 18
              a little upd on the whole situation, replacement procedures I believe were done correctly and it had pass all the adj but I'll do toner density initiation again, yet it's just a weird start of error parade coming next such as now throwing 2243, couldn't find code for I/O checking of the drum speed (drum is new just installed)
              • sendpiks
                • Dec 2017
                • 21
                Highly likely this is problems with shutter for IDC sensors, I have very similar problems on my 8000. Solution was to keep IDC sensors opened all the time. Tape it in open position and DO NOT make registration auto adj. Color gamma adj make from front panel menu as usual.
                Maybe it will help.
                • sendpiks
                  • Dec 2017
                  • 21
                  Do you screwed out and throw away small RED screws on drums?
                  One time when I was at very very beginning of my Konica way I put new drums without taking out red screws and this give looots of funny errors
                  • schlf
                    • Feb 2022
                    • 18
                    Exactly my problem to be honest, didn't know that was a thing and was just checking if drums are identical.
                    Thanks a lot everyone for help
                    • Robin (ACS Collective)
                      • Nov 2021
                      • 21
                      hi,
                      i am getting 4661 on our C6000 after replacing transfer belt cleaning unit.
                      Didn't find any screws to be removed. But are there any?
                        • 23009
                        Originally posted by Robin (ACS Collective)
                        hi,
                        Oh yes. There are (2) locking screws painted red, holding the cleaning blade away from the belt. You can remove them completely. =^..^=
                          • Nov 2021
                          • 21
                          Thanks but, no those screws were already gone.
                          I compared old and new units.
                          Another question:
                          Do you think I can use "A1RFPP0000 Setting Toner" for our C6000?
                          It says it was compatible with bizhub PRESS C1100/C1085/C6100/C6085/C8000.
                            • 23009
                            For the amount needed to prime a drum or transfer cleaning blade, any differences will be insignificant. Yes, use that.
                              • Nov 2021
                              • 21
                              Journey continues:
                              What exactly is SETTING POWDER 000V-19-0?
                              Our Konica Dealer sent this instead of A1RFPP0000 Setting Toner.
                              As it is white and contains little plastic bubbles I guess I should rather not use this instead?
                              Sorry for my noob qs
