Image Repeating Issue in bizhub c454e
  • imageprintingservices
    • Jan 2019
    • 3
    I am facing image repeating issue (see attachment). Everyhitng is fine till last working day when i close my printing setup and today first print same like this...
  • Toxic
    • 694
    Re: Image Repeating Issue in bizhub c454e
    Check fusing belt for damage.
    Looks like drum K is also bad...
    Did it occur on all paper weights?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4544
      Looks like you need magenta drum and like other poster said black drum. If it was happening on all colors I would look at transfer belt or fuser belt mentioned in previous post.
      Also are you using genuine or aftermarket toner?
      • Konicatech
        • Feb 2016
        • 131
        As said above, change the drums and after that do stabilization.
        Quality should clear up after new parts but if the image is still repeating I would put some OEM toner in the machine and run solid CMYK patterns through it until it clears up, as it can happen on the compatible toners due to them not having any dev carrier in them.
        • allan
          RTFM!!
          • 5459
          Please let us know what toner you are using.
          That sample is giving me a headache. How does mostly one color get stuck to the fusing roller?
          Look at the bird image that gets ghosted in magenta about a fusing belt circumference later. Coincidentally falls nicely in the text box
          Like Toxic said check the fuser belt surface. The black gets picked up next.
          Don't think its a drum could be over toning.
          Changing background image adjust for M and K would confirm if the drum is at fault.
          Whatever
          • copyman
            Owner / Technician
            • Sep 2005
            • 4544
            Nothing to do with over toning. It has to do with magenta drum cleaning blade (or bad toner). Simple to troubleshoot, swamp drum with another color from same machine and see if repeat image changes to color you swapped drum with.
            • Toxic
              • 694
              Most likely there is several problems there, not just one.
              I don know why but i have feeling this is higher counter machine poorly maintained and propably with aftermarket toners.
              • tsbservice
                Field tech
                • 7926
                +1. This machine looks like toasted. Maybe fixing it would cost a lot - drums, developer units, toner etc.
                • allan
                  RTFM!!
                  • 5459
                  Looking the repeating distance it could very well be a drums. What bothers me here is that it happened over night as per the OP. Hard to believe.
                  Would agree it needs a proper service and a bunch of consumable parts.
                  Whatever
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4544
                    This is what happens all the time. Original poster asks their first question on the forum several techs waste their time answering and you never hear back from them! Probably because they are using aftermarket parts & toners and didn't like hearing the truth. Either way they will eventually know the FREE help they received here was true and good advice.
                    • Gift
                      • Mar 2011
                      • 2447
                      let's give him another day^^
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4544
                        Ha-ha! I could care less if they ever reply. I gave my advice and have nothing more to add. Perhaps if they become a contributor to this forum & provide more information I will offer more support.
                        • tsbservice
                          Field tech
                          • 7926
                          That is why I didn't hold a bit my opinion 😅
                          If it's a fellow tech that is another story for me.
                          You know all nasty staff they throw everyday at us...
                            • Jan 2019
                            • 3
                            First appologies for the long delay....extremely occupied in work ...... after fixing my machine and printing 12500 sheets i am writing this post. I did few things ....
                            1. Pullout filter (back side of machine) clean with blower it again reinstall.
                            2. For full colored print of a single color i put white paper sheet on glass and make 50 blank copies (i taught drum got over toned) after 40+ blank white copies that over tone issue resolved automatiacally.
                            3. pullout cables (white colored) form PWB-VD2 board under power supply clean them and put them again in board and didn't face that problem again.
                            I think it happend because of moister in air and rainy season in our city. I use TN-615 in my machines. i dont know it is good for this model or not but i am extermely satisfied with its performance and consistent result.
                            This is only my opinion and what i feel and think to fix my machine, experts know well.
                            Regards,
                            Tariq
