Bizhub C250i drums
  • tsbservice
    Field tech
    • 8013
    Bizhub C250i drums
    Anyone having success cleaning DR-316/K PCRs. Recently had one C250i with few thin lines on prints in paper feeding direction and traced the lines to PCR.
    I highly doubt that drum dissasembly and cleaning will work but who knows better than experienced.
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C250i drums
    I have tried with mixed results. The old Panasonic Workio and even older RICOH machines had a tough roller and could be scrubbed with a cloth and running water. So I tried that with the KM roller and some of the coating came off. Got it right went I soaked it in water till the paper dust on it softened and lightly cleared it of with a cloth. Then the first time i did not wait for it to dry properly and it produced a background.
    Second attempt worked. But who has the time for that?
    PCR it same as charge roller right?
    RICOH manual stated to clean with soft cloth and saliva!
    Whatever
    • tsbservice
      Field tech
      • 8013
      Yes allan PCRs are charging rollers. They are hard one type not soft type like in Brother machines which I have no problems to clean with water/soft soap and reuse them hundred times. I don't want to take path of rebuilding drum unit with aftermarket parts like drum, cleaning blade, PCR, PCR cleaning helical roller etc.
      Just want to know if I can save them somehow because drum itself isn't looking damaged.
      The lines on print are very thin but are visible on PCR and seems to me cannot be cleared.
      • allan
        RTFM!!
        • 5462
        Ok. Its not the worst to remove it. Give it a try.
        Whatever
        • copyman
          Owner / Technician
          • Sep 2005
          • 4700
          I haven't had much sucess cleaning the PCR's once they have lines scored into roller. If just dirty I use Nu-Finish car polish (orange btl, auto parts stores, walmart, etc). Let dry and buff with soft cloth. Been using it on PCR's for many years.
          I rebuild the "8" series drum units with new blade, PCR & drum. They work as good or better than OEM. Not sure if the "i" series drum units use same PCR but they are only $10.
