full black page in bizhub 185 after replacing parts
  • user00
    • Jul 2022
    • 2
  • Toxic
    • 698
    Re: full black page in bizhub 185 after replacing parts
    I would check first for some bad HV contacts, between IU assy and machine, drum, charge unit...
    If you have other working IU assy try to replace it and see if that resolve problem then search for cause.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4738
      As other poster said check image unit again. Something isn't making contact for high voltage.
      The reason it's jamming in fuser is because of black page sticking to fuser rollers.
      • tsbservice
        Field tech
        • 8031
        Why you put so many parts in that piece of junk machine is beyond me but yes check your drum unit for missing/leaking main charge when you solve that it would consequently stop jamming in fuser.
        • user00
          • Jul 2022
          • 2
          Think you man, as you suggested the problem was in the charger unit which was not correctly placed.
          Now the copier works perfectly
