series 4 main menu
  • romario
    • Jun 2020
    • 187
    series 4 main menu
    Does anyone know if you can change the wallpaper of a konica c224e apart from the 3 default backgrounds that come with the machine (put an image that you want) ... I can do that in the 8 series, c308, c368, etc and on i-series, c300i, c450i etc
    thanks
  • tsbservice
    Field tech
    • 7970
    Re: series 4 main menu
    As far as I remember that won't work on 4/4e series. You will need IT5(7/8/9 series) machine or newest.
    • romario
      • Jun 2020
      • 187
      Perfect, I had that doubt, thanks I will not try anymore
      thanks
      • techsxge
        • Jan 2022
        • 660
        I am still trying to figure out a way, but it looks like the machines just do not have that function at all. Support cant help either.
        I heard someone once did it with the KM marketplace tho
        • copyman
          Owner / Technician
          • Sep 2005
          • 4613
          • tsbservice
            Field tech
            • 7970
            Originally posted by copyman
            It can be done. I've had several off lease "4" series where the previous dealer had their logo pop up on the boot screen.
            Sure it can be done but I'm afraid boot up screen is different from wallpaper he asked
            • copyman
              Owner / Technician
              • Sep 2005
              • 4613
              ha-ha Missed that. had it confused with other post. going to delete it.
              • tsbservice
                Field tech
                • 7970
                We avoid Marketplace even on newest IT6 i series. Could imagine this plague would demolish old but crusty 4e down to the speed of tortoise or even freeze.
                • techsxge
                  • Jan 2022
                  • 660
                  i never used marketplace anyways.
                  Main reason to not use it is that the machines should never get a internet connection in the first place. Only have 1 client that does grant internet access and that was after alerting the customer multiple times about the security issues and now its extremely filtered connection
