C3320i with Fax Board
  • albemero
    • Apr 2019
    • 37
    Hi Folks
    We sold a new C3320i + FK-517.
    the customer want to send fax and she want the tx report with the first page printed on the tx report.
    I ve set it in Service Mode but the tx report is not printed always with the first seite on it.
    The Firmware is KJ and SW 25 is set to 30Hex.
    I hope all I ve write is understandable.
    Thak you for your time
  • JasonSBE
    • Apr 2014
    • 186
    Re: C3320i with Fax Board
    Assuming you have the Fax Kit installed correctly, the default setting will be to only print a tx report if the fax fails to go through. You need to go to the administrator menu and in the fax section you should have a setting to turn the report on for every fax.
    • Firmaware
      • 30
      The tx report is printed every time. The tx ve always success. One time is the tx report printed with the first seite, other times without.
      Gesendet von meinem SM-G980F mit Tapatalk
      • Synthohol
        Certified Konica Expert
        • 5846
        in service mode, fax, list output select "with image"
        • Firmaware
          • 30
          The customer hat tipped simply the telephone icon in the upper parts of display. Thanks all
