Konica C3110 FK-512 installation issue
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Installed the FK-512 fax kit, done it many times before and they are usually plug and play and the fax options then appear automatically in both service mode and utility/admin mode.
    Not on this unit though. Any ideas? Thanks in advance.
  • femaster
    • May 2011
    • 1500
    Re: Konica C3110 FK-512 installation issue
    According to the installation guide, that is all that is needed for it to show up in the system. I see there are 3 possible connections for the USB cable on the system board, so make sure it is connected to correct one and it should show up.
