BH-C-284e, two issues
  • Hansoon
    • Sep 2007
    • 3355
    First:
    BH-C-284e, machine shows from time to time "An internal error has occurred. System will reboot and error will be cleared.
    Second:
    machine can be pinged, but the web interface cannot be reached and scans and prints are not executed.
    Sleep mode is off and FW is FW_A5C10Y0-F000-GDT-M1
    Any ideas please?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • Kenny
    • Jun 2009
    • 515
    Re: BH-C-284e, two issues
    Originally posted by Hansoon
    First:
    Second:
    Any ideas please?
    Hans
    1st - machine has the auto 'internal error auto cancel' enabled (service mode - system 2 - next page - internal error auto cancel - RANK B OR C is turned on) check the service error history in service mode to see what the code was.
    2nd - i have had this when the network speed wasn't correct (administrator settings - network settings - detail settings - device settings - can adjust network speed there) when i turned in on to AUTO 10M/100M/1GBPS the machine began to print etc..
    • Cantechman
      • Nov 2008
      • 226
      First:
      Second:
      Any ideas please?
      Hans
      If you log into service mode and check the counters you should be able to see the error code there under one of the categories. I had the same model give the internal error message, it would try and reset it but come back a second after it the copy screen appeared upon bootup. it showed several different codes. In the end a hard drive error was the most dominate code, i replaced it and the machine is fine now.
        • 22960
        Yes, you need to see what the code is. In my experience the most common "internal error" is C2557: black developer density.
