8 1/2 x 11 duplex jams
  • Jimdale
    • Apr 2022
    • 4
    [Jamming] 8 1/2 x 11 duplex jams
    I have a C1070 that jams intermittently (1 to 20 prints) duplex 8 1/2 x 11 LEF only. All other media runs, i.e. 11x17, 8 /15 x 14, 8 1/2 x 11 SEF. The code is J-3101. I have installed the latest firmware, checked the paper path. I have a new registration assembly ordered just in case. Any help is appreciated!
  • Old_Tech
    • Apr 2022
    • 10
    Re: 8 1/2 x 11 duplex jams
    I would look at the reverse section paper detect actuator. The paper wears down the end of it.
      • 23009
      You may have paper scraps in the registration inlet, that are difficult to remove:
      Misfeeds duplex J3209, J3101, J3120. Jam clears but returns. Paper jam is difficult to recover from the lower registration inlet. Insert a sheet of heavy mylar at the lower registration path to press the paper jam back down to the ADU pre-registration roller. Remove the paper scraps from the openings around the ADU pre-registration roller, viewable from the underside of the imaging drawer.
