konica minolta bh di250
  • T911
    • Jun 2007
    • 628
    How do i calibrate the developer and reset the drum count after rebuilding it or does the fuse reset the drum. I also will need the service mode procedure to calibrate dev atdc. Thanks
  • Hansoon
    • Sep 2007
    • 3360
    Re: konica minolta bh di250
    With the fuse, both drum and developer counters are reset and the calibration procedure is initiated. No need for further action. Be sure to have a new drum and new developer powder, otherwise you are asking for print quality trouble. Ideally replace the mag roller collars too.
    Very doubtful if rebuilding the Image Unit is economically......
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • T911
      • Jun 2007
      • 628
      Hans
      Great thanks
      • copyman
        Owner / Technician
        • Sep 2005
        • 4575
        As hans says best to replace at least the rear dev roller collar or drum will wear excessively on that end. New style collars are available with bearing in center.
        • REGSIS
          • May 2016
          • 434
          For EP and Di series calibration is done by executing F8 IIRC. Fuse just reset drum counter.
          Use F8 only if developer is replaced.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4575
            You might have models confused. On this DI series Drum message & dev calibration is done when fuse blows on new IU.
            F8 in tech rep mode is for factory use only (see attached)
            • REGSIS
              • May 2016
              • 434
              Yep, this model uses IU. You're right.
