Is it possible to adjust how firmly a door closes on an 8 series machine?
  • JasonSBE
    • Apr 2014
    • 183
    #16
    Re: Is it possible to adjust how firmly a door closes on an 8 series machine?
    Thanks for all the solid tips on this issue. I tried the washer method and it didn't work. Adjusting the hinges and then shimming the latch points did the trick.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4637
      #17
      Thanks for the follow up.
      Actually the washer fix may be for the "4" series only. I only posted the bulletin with the washers because someone mentioned it.
