Konica Minolta C368 P-22
  • tech51
    • 846
    #16
    Re: Konica Minolta C368 P-22
    Originally posted by Kenny
    it then brings up a P-14 code
    • tmmdmmm
      • Apr 2021
      • 173
      #17
      Originally posted by tech51
      Well you seem to have done everything except replacing the ph unit. I’ve had these go faulty on this model a couple of times so might be worth trying that.
      Cheaper to replace the Belt and KDR first, everything is referenced off black.
      P codes were mentioned but was there an actual color registration issue? P22s and color reg for me has always been the belt, but I've always replaced the KDR anyway just to avoid the callback. Almost every time these have been well under life.
      And if you're running into color reg issues they tend to be temporarily fixed by stabilizing. IE Stabilize and it looks great, but slowly drifts over 500 pages then looks good again after it stabilizes.
      • REGSIS
        • May 2016
        • 435
        #18
        Reset print heads (you will hear clicking sound 4 times)
        Initialization and stabilization.
        OFF/ON
        You will solve P-14 with this.
        P-22 can be related with P-14, so should be gone along with P-14.
        If this doesn't help try to switch PH unit from a working machine and see if it helps.
        • Kenny
          • Jun 2009
          • 529
          #19
          Hi guys,
          just a quick update, i have replaced the PH UNIT and PHRYB and it has solved the issue!
          so just want to say a big thank you to everyones input, the support on this site is phenomenal!
          • Hansoon
            • Sep 2007
            • 3389
            #20
            Thanks for that valuable feed back, Kenny!
            Hans
            • tsbservice
              Field tech
              • 8020
              #21
              Hans
              Yes, it really helps community when someone follow up.
              Btw, tech51 is always spot-on reminded me Toshiba UK guys who were/are pretty much experienced and capable.
              • tech51
                • 846
                #22
                • tsbservice
                  Field tech
                  • 8020
                  #23
                  Your experience is awesome and really appreciated from my point of perspective
