Konica Minolta C368 P-22
  • Kenny
    • Jun 2009
    • 529
    Hi guys,
    got a machine that constantly has P-22 code (colour reg adjust failure)
    i have reseated all drums + devs. i have replaced both the IDC sensors, tried intialize and stabilization, ran gradation adjustment, also ran print head skew adjust, am going to try FRB next but does anyone have any other suggestions?
    consumable lifes are all about 50%
  • pickle8486
    • Aug 2013
    • 26
    Re: Konica Minolta C368 P-22
    Check the transfer belt, if it is worn replace it. You will sometimes get the 3-d effect also. What happens is there are tiny scratches on the belt right where the idc reads toner on the belt.
    Sent from my SM-N986U using Tapatalk
    • allan
      RTFM!!
      • 5462
      Do you get clear CMYK half tones at 125?
      Whatever
      • Kenny
        • Jun 2009
        • 529
        i have tried replacing the transfer belt and the problem persists
        • Kenny
          • Jun 2009
          • 529
          yes get full halftones,
          the machine keeps on changing from P-14 to P-22S45C-6e22081204530.pdfS45C-6e22081204530.pdfS45C-6e22081204530.pdf
          • Tiagocang
            • Feb 2022
            • 62
            i would give 1 more try at changing IDC sensors again
            • allan
              RTFM!!
              • 5462
              Is the IDC sensor shutter working properly. It gets stuck if you clean in that area. Remove that section again and check if the solenoid can do its job.
              Whatever
              • Cantechman
                • Nov 2008
                • 228
                Originally posted by Kenny
                Hi guys,
                I would try the FSB. Since the IDC sensors connect to it (if i'm not mistaken) and since you already replaced the sensors I would look there.
                I would also make sure the IDC sensor shuttle is working. Jig it open and see if the error goes away.
                Last edited by Cantechman; 08-12-2022, 01:45 PM. Reason: I would also make sure the IDC sensor shuttle is working.
                • Kenny
                  • Jun 2009
                  • 529
                  ive replaced the FRB and jigged the shutter issue still persists??
                  • tsbservice
                    Field tech
                    • 8020
                    What happens if you run Stabilizer (Initialize + Image stabilization)?
                    • allan
                      RTFM!!
                      • 5462
                      It can go out of alignment ever so slightly it seems open but still not correct.
                      You cab jig the door and the fuser and have a look if the patches are all there.
                      Whatever
                      • Kenny
                        • Jun 2009
                        • 529
                        it then brings up a P-14 code
                          • 23009
                          Cyan developing isn't that great. Not sure if it will help. =^..^=
                          • dantab1980
                            DanTab
                            • May 2015
                            • 16
                            Time to bring out the electrical diagram and trace the wiring to the issue. Might be a high/low voltage issue.
                            • allan
                              RTFM!!
                              • 5462
                              That is easy to see just check the IDC sensor values under state confirmation. I have had good values but the shutter did not not seem to close and that also gave P-codes.
                              Whatever
