Replace actuator (A0ED703800) of sensor PS2 - Konica C258
  • g0ldzer4
    • Jun 2022
    • 6
    Hi friends, i have one KM C258 needing to replace actuator A0ED703800 of sensor PS2, but i don't find in manual service the procedure to replace. Someone can help please? If have also a video and can send to me will help so much, thanks friends.
  • femaster
    • May 2011
    • 1527
    Re: Replace actuator (A0ED703800) of sensor PS2 - Konica C258
    If you have a parts manual, it has a breakdown of what the transfer unit looks like. It's not really all that complicated. If you look at the same page the actuator is shown on, you just remove part #13 (A5C1711801) "Support Plate /Front", and the whole assembly that holds the transfer roller practically jumps out at you. It is spring loaded, so be careful when removing that piece. You may have to slide the plastic assembly to the right to dislodge the clips from the metal back plate, but that is all there is to it. Pull the single wire harness connector and you can then remove it from the machine. Swap out the actuator arm and reassemble.
    • g0ldzer4
      • Jun 2022
      • 6
      Thanks for you help friend, i don't have the parts manual, just service manual. If you have can send me in PM?
      • femaster
        • May 2011
        • 1527
        I don't have a means to share the whole parts manual, but I've included a capture of the page with the part(s) highlighted. Hope that it helps you out.
        • g0ldzer4
          • Jun 2022
          • 6
          [ATTACH=CONFIG]54382[/ATTACH]
          Thanks so much friend.
