PC home sensor (K) malfunction. Perform faulty sensor check. During stabilize mode, phase detect sensor should change values. Clean if needed. Could be transport drive assembly or PRCB.
Good luck and may the schwartz be with you.
We have the same problem on a C450, only happens during B/W copying.
So far we have replaced the sensors (PC11/PC36), K PC Drum drive assy, PWB-MC & PWB-MFP but have not solved the problem.
